Alfa Giulia / Stelvio 2.0 vollständige Fehlercode Liste
    • Neu
    Im csv Format
    Kategorie,DTC,Beschreibung,SubFaults,Offset
    FuelSystem,P0002,Fuel Volume Regulator Control Circuit Range/Performance,,0x74AE30
    FuelSystem,P0003,Fuel Volume Regulator Control Circuit Low,"P0004 P0001",0x74B160
    FuelSystem,P0088,Fuel Rail Pressure Too High,P0087,0x74B440
    FuelSystem,P018B,Fuel Pressure Sensor B Circuit Range/Performance,,0x74B3A8
    FuelSystem,P018C,Fuel Pressure Sensor B Circuit Low,P018D,0x74B178
    FuelSystem,P0191,Fuel Rail Pressure Sensor Circuit Range/Performance,,0x74AFF0
    FuelSystem,P0192,Fuel Rail Pressure Sensor Circuit Low,P0193,0x74ADA0
    FuelSystem,P01BA,Fuel Injector Group A Supply Voltage Circuit,,0x74B4B0
    FuelSystem,P01BB,Fuel Injector Calibration Cylinder 1,P01BC,0x74AF68
    FuelSystem,P01C0,Fuel Injector Calibration Cylinder 3,P01C1,0x74AFE8
    FuelSystem,P053F,Cold Start Fuel Pressure Performance,,0x74B600
    FuelSystem,P152D,Hochdruck Kraftstoffpumpe Regelung,P152E,0x74B448
    FuelSystem,P152F,Hochdruck Kraftstoffpumpe Performance,,0x74B450
    AirSystem,P0100,Mass Air Flow Sensor Circuit,,0x74AEF0
    AirSystem,P0101,Mass Air Flow Sensor Circuit Range Performance,,0x74B3A0
    AirSystem,P0102,Mass Air Flow Sensor Circuit Low,P0103,0x74AF88
    AirSystem,P0106,MAP Sensor Circuit Range Performance,,0x74B388
    AirSystem,P0108,MAP Sensor Circuit High,P0107,0x74ABC8
    AirSystem,P0111,Intake Air Temperature Sensor 1 Range Performance,,0x74AE90
    AirSystem,P0112,Intake Air Temperature Sensor 1 Circuit Low,P0113,0x74ABE0
    AirSystem,P0116,Engine Coolant Temperature Sensor Range Performance,,0x74AE88
    AirSystem,P0117,Engine Coolant Temperature Sensor Circuit Low,P0118,0x74ABD8
    AirSystem,P0128,Coolant Thermostat Below Regulating Temperature,,0x74B650
    Turbo,P0035,Turbo Supercharger Bypass Valve Control Circuit High,"P0034 P0033",0x74ADC8
    Turbo,P0039,Turbo Supercharger Bypass Valve Control Range Performance,,0x74ADC0
    Turbo,P00D2,Turbo Supercharger Boost Control B Performance,,0x74B928
    Turbo,P00DF,Turbo Supercharger Boost Control A Stuck Closed,,0x74B380
    Turbo,P00E0,Turbo Supercharger Boost Control Slow Response,P00E1,0x74AF70
    Turbo,P00F3,Turbo Supercharger Temperature 1 Sensor Range Performance,,0x74B298
    Turbo,P00F4,Turbo Supercharger Temperature 1 Sensor Circuit Low,P00F5,0x74B188
    Turbo,P022B,Barometric Pressure Boost Pressure Correlation,P022C,0x74AFD0
    Turbo,P0236,Turbo Supercharger Boost Sensor A Circuit,,0x74B780
    Turbo,P0237,Turbo Supercharger Boost Sensor A Circuit Low,P0238,0x74AC80
    Turbo,P023B,Turbo Boost Control A Position Not Reached,"P023C P023A",0x74B168
    Turbo,P0244,Turbo Supercharger Wastegate Solenoid A Range Performance,,0x74B980
    Turbo,P0245,Turbo Supercharger Wastegate Solenoid A Low,"P0246 P0243",0x74AF40
    Turbo,P024A,Turbo Supercharger Boost Control B Slow Response,,0x74B960
    Turbo,P024B,Turbo Supercharger Boost Control B Position Not Reached,,0x74B958
    Turbo,P026E,Turbo Boost Pressure Slow Response,,0x74B6B8
    Turbo,P0299,Turbo Supercharger Underboost,P0234,0x74BA78
    Turbo,P164E,Turbolader Ölzufuhr Performance,,0x74B670
    Turbo,P2262,Turbo Boost Pressure Not Detected Mechanical,,0x74AE48
    Turbo,P257E,Turbo Boost Control A Supply Voltage Low,"P257F P254F",0x74B500
    Turbo,P26E4,Manufacturer Specific Turbo,,0x74BA10
    Turbo,P26E5,Manufacturer Specific Turbo,,0x74BA18
    Turbo,P26E6,Manufacturer Specific Turbo,,0x74BA08
    Turbo,P26F0,Manufacturer Specific Turbo,,0x74BA20
    Turbo,P26F2,Manufacturer Specific Turbo,,0x74AEF8
    Injector,P0261,Cylinder 1 Injector Circuit Low,"P0262 P0201",0x74AC30
    Injector,P0264,Cylinder 2 Injector Circuit Low,"P0265 P0202",0x74AC38
    Injector,P0267,Cylinder 3 Injector Circuit Low,"P0268 P0203",0x74AC40
    Injector,P02EE,Cylinder 1 Injector Circuit Range Performance,,0x74B620
    Injector,P02EF,Cylinder 2 Injector Circuit Range Performance,,0x74B628
    Injector,P02F0,Cylinder 3 Injector Circuit Range Performance,,0x74B630
    Injector,P02F1,Cylinder 4 Injector Circuit Range Performance,,0x74B638
    Ignition,P0611,Fuel Injector Control Module Performance,,0x74B9D0
    Ignition,P0615,Starter Relay Circuit,,0x74B738
    Ignition,P0616,Starter Relay Circuit Low,P0617,0x74AE28
    Ignition,P1061,Zündspule Zylinder 1,,0x74AEC0
    Ignition,P1062,Zündspule Zylinder 2,,0x74AEC8
    Ignition,P1063,Zündspule Zylinder 3,,0x74B000
    Ignition,P1064,Zündspule Zylinder 4,,0x74B008
    Ignition,P1300,Zündung Allgemeiner Fehler,,0x74BAD0
    Ignition,P2301,Ignition Coil A Primary Control Circuit High,P2300,0x74AC50
    Ignition,P2302,Ignition Coil A Secondary Circuit,,0x74B9D8
    Ignition,P2304,Ignition Coil B Primary Control Circuit High,P2303,0x74AC58
    Ignition,P2305,Ignition Coil B Secondary Circuit,,0x74B9E0
    Ignition,P2307,Ignition Coil C Primary Control Circuit High,P2306,0x74AC60
    Ignition,P2308,Ignition Coil C Secondary Circuit,,0x74B9E8
    Ignition,P2310,Ignition Coil D Primary Control Circuit High,P2309,0x74AC68
    Ignition,P2311,Ignition Coil D Secondary Circuit,,0x74B9F0
    Misfire,P0300,Random Multiple Cylinder Misfire Detected,,0x74B040
    Misfire,P0301,Cylinder 1 Misfire Detected,,0x74B048
    Misfire,P0302,Cylinder 2 Misfire Detected,,0x74B050
    Misfire,P0303,Cylinder 3 Misfire Detected,,0x74B058
    Misfire,P0304,Cylinder 4 Misfire Detected,,0x74B060
    Misfire,P0363,Misfire Detected Fueling Disabled,,0x74B038
    Network,U0001,High Speed CAN Communication Bus,,0x74ADF0
    Network,U0002,High Speed CAN Communication Bus Performance,,0x74B930
    Network,U0101,Lost Communication With TCM,,0x74ADF8
    Network,U0121,Lost Communication With ABS,,0x74ADE0
    Network,U0140,Lost Communication With BCM,,0x74ADE8
    Network,U0151,Lost Communication With Restraints Control Module,,0x74B9A0
    Network,U0155,Lost Communication With Instrument Panel Cluster,,0x74ADD8
    Network,U0402,Invalid Data Received From TCM,,0x74B858
    Network,U0405,Invalid Data Received From TPMS,,0x74AD88
    Network,U040F,Invalid Data Received From EPS,,0x74AEE8
    Network,U0415,Invalid Data Received From ABS,,0x74B850
    Network,U0417,Invalid Data Received From Parking Brake Module,,0x74B710
    Network,U0422,Invalid Data Received From BCM,,0x74B6C0
    Network,U0423,Invalid Data Received From Instrument Panel Cluster,,0x74B860
    Network,U0426,Invalid Data Received From Immobilizer Module,"U0427 P0633 P0513",0x74ACF0
    Network,U0452,Invalid Data Received From Restraints Module,,0x74B718
    Chassis,C0501,Vehicle Speed Information Circuit,,0x74B888
    Chassis,C0507,Vehicle Speed Information Circuit Low,,0x74B890
    Chassis,C050D,Vehicle Speed Information Circuit High,,0x74B898
    Chassis,C0513,Vehicle Speed Information Circuit Intermittent,,0x74B8A0
    Chassis,C051C,Vehicle Speed Information Circuit Performance,,0x74B8D0
    Chassis,C0608,Manufacturer Specific Chassis,,0x74B5A0
    Body,B1810,Manufacturer Specific Body Comfort,B1811,0x74B470
    Body,B1813,Manufacturer Specific Body Comfort,B1814,0x74B488
    Body,B1B50,Manufacturer Specific Body,B1B51,0x74B468
    Body,B25C7,Manufacturer Specific Body,B25C8,0x74B478
    Body,B25CB,Manufacturer Specific Body,,0x74B480
  • Perfecto. Danke. Das hilft mir Sicherheit einigen 👍
    Vielleicht kannst du mal die KI drüber laufen lassen und das nach Fehlercode ordnen 😉
    Keep calm and love Alfa Romeo
    • Neu
    Mach das doch selber in Excel oder Google Sheet.
    Das CSV ist nach Kategorie groupiert. :wink:
